Guten Abend,
ich habe das Problem, dass mein einer Fenstersensor im Config Pending hängen bleibt.
Ich wollte ihn nun auf factory resetten… auch da passiert nichts und er bleibt hängen. Hier der Log. Ich weiß nicht so ganz was ich nun noch machen kann.
10/31/19 09:56:35.454 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:36.076 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:37.207 RPC Server (Port 2002): Error: Broken pipe
10/31/19 09:56:38.892 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:42.791 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:42.822 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:53.952 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 09:56:54.140 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:54.173 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:54.206 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 09:56:54.261 RPC Server (Port 2002): Warning: TLS handshake has failed: A TLS fatal alert has been received.
10/31/19 10:50:56.260 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 11:51:54.868 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 12:51:22.173 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 13:50:03.732 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 14:49:33.184 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 15:50:46.094 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 16:43:08.835 Error: No AES key is defined for the key index to set. You probably changed rfKey before the last key was sent to the device or you forgot to set oldRfKey. Please set oldRfKey in homematicbidcos.conf to the current AES key of the peer or reset the peer and pair it again.
10/31/19 16:56:36.369 Module HomeMatic BidCoS: Error: Peer deletion took too long.
10/31/19 16:56:36.401 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
10/31/19 16:56:36.403 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
10/31/19 16:56:36.415 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
10/31/19 16:56:36.424 Module HomeMatic BidCoS: Error: Packet was processed more than 5 seconds after reception. If your CPU and network load is low, please report this to the Homegear developers.
