I want to install homegear on a raspberry pi armv6h. Therefore I have downloaded the package from AUR and modified the PKBUILD to support armv6h.
During the build I recevie errors that
error: ‘function’ in namespace ‘std’ does not name a template type
or
error: ‘std::function’ has not been declared
I don’t know whats wrong here because -std=c++11 is set ?!?
checking for strchr... yes
checking for strerror... yes
checking for strstr... yes
checking for strtol... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
make all-recursive
make[1]: Entering directory '/tmp/libhomegear-base-git/src/libhomegear-base'
Making all in src
make[2]: Entering directory '/tmp/libhomegear-base-git/src/libhomegear-base/src'
depbase=`echo BaseLib.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
/bin/sh ../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I.. -Wall -std=c++11 -DFORTIFY_SOURCE=2 -DGCRYPT_NO_DEPRECATED -D_FORTIFY_SOURCE=2 -DLINUXSYSTEM -march=armv6 -mfloat-abi=hard -mfpu=vfp -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -MT BaseLib.lo -MD -MP -MF $depbase.Tpo -c -o BaseLib.lo BaseLib.cpp &&\
mv -f $depbase.Tpo $depbase.Plo
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I.. -Wall -std=c++11 -DFORTIFY_SOURCE=2 -DGCRYPT_NO_DEPRECATED -D_FORTIFY_SOURCE=2 -DLINUXSYSTEM -march=armv6 -mfloat-abi=hard -mfpu=vfp -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -MT BaseLib.lo -MD -MP -MF .deps/BaseLib.Tpo -c BaseLib.cpp -fPIC -DPIC -o .libs/BaseLib.o
In file included from Encoding/XmlrpcEncoder.h:38:0,
from BaseLib.h:37,
from BaseLib.cpp:31:
Encoding/../Output/Output.h:97:7: error: 'function' in namespace 'std' does not name a template type
std::function<void(int32_t, std::string)>* getErrorCallback();
from BaseLib.h:37,
Encoding/../Output/Output.h:104:29: error: 'std::function' has not been declared
void setErrorCallback(std::function<void(int32_t, std::string)>* errorCallback);
Encoding/../Output/Output.h:104:37: error: expected ',' or '...' before '<' token
Encoding/../Output/Output.h:247:7: error: 'function' in namespace 'std' does not name a template type
std::function<void(int32_t, std::string)>* _errorCallback = nullptr;
In file included from BaseLib.h:62:0,
ScriptEngine/ScriptInfo.h:102:7: error: 'function' in namespace 'std' does not name a template type
std::function<void(PScriptInfo& scriptInfo, std::string& output)> scriptOutputCallback;
ScriptEngine/ScriptInfo.h:103:7: error: 'function' in namespace 'std' does not name a template type
std::function<void(PScriptInfo& scriptInfo, PVariable& headers)> scriptHeadersCallback;
ScriptEngine/ScriptInfo.h:107:8: error: 'function' in namespace 'std' does not name a template type
std::function<void(PScriptInfo& scriptInfo, int32_t exitCode)> scriptFinishedCallback;
In file included from BaseLib.cpp:31:0:
BaseLib.h:189:29: error: 'std::function' has not been declared
BaseLib.h:189:37: error: expected ',' or '...' before '<' token
BaseLib.cpp:60:43: error: variable or field 'setErrorCallback' declared void
void SharedObjects::setErrorCallback(std::function<void(int32_t, std::string)>* errorCallback)
BaseLib.cpp:60:43: error: 'function' is not a member of 'std'
BaseLib.cpp:60:43: note: suggested alternative: 'is_function'
is_function
BaseLib.cpp:60:77: error: expression list treated as compound expression in functional cast [-fpermissive]
BaseLib.cpp:60:52: error: expected primary-expression before 'void'
make[2]: *** [Makefile:869: BaseLib.lo] Error 1
make[2]: Leaving directory '/tmp/libhomegear-base-git/src/libhomegear-base/src'
make[1]: *** [Makefile:403: all-recursive] Error 1
make[1]: Leaving directory '/tmp/libhomegear-base-git/src/libhomegear-base'
make: *** [Makefile:335: all] Error 2
==> ERROR: A failure occurred in build().
Aborting...
[alarm@alarmpi libhomegear-base-git]$ gcc --version
gcc (GCC) 7.1.1 20170516
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
