ich habe heute homegear vom git aktualisiert. Homegear empfängt alle Pakete von den Aktoren und Sensoren. Aber ich kann keine Aktoren mehr ansteuern. Ich bekomme die gleiche Fehlermeldung wie Frank.
Die Funksteckdose sendet Daten, welche von Homegear empfangen werden:
03/26/17 18:23:25.522 Info: Publishing topic homegear/1234-5678-9abc/plain/6/2/ENERGY_COUNTER 03/26/17 18:23:25.522 Info: Publishing topic homegear/1234-5678-9abc/jsonobj/6/2/ENERGY_COUNTER 03/26/17 18:23:25.522 Info: Publishing topic homegear/1234-5678-9abc/json/6/2/FREQUENCY 03/26/17 18:23:25.523 Info: Publishing topic homegear/1234-5678-9abc/plain/6/2/FREQUENCY ....
Wenn ich jedoch die Steckdose schalten möchte, bekomme ich auch die UNREACHABLE Fehlermeldung:
03/26/17 18:25:32.842 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 6). Retrying...
03/26/17 18:25:32.942 HM-LGW "My-HM-LGW": Info: Sending (My-HM-LGW): 0E3BA011DEAD793ACD160201000000
03/26/17 18:25:34.945 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
03/26/17 18:25:34.945 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 6). Retrying...
03/26/17 18:25:35.045 HM-LGW "My-HM-LGW": Info: Sending (My-HM-LGW): 0E3BA011DEAD793ACD160201000000
03/26/17 18:25:37.048 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
03/26/17 18:25:37.048 Info: Peer 6 is unreachable.
03/26/17 18:25:37.048 Info: Publishing topic homegear/1234-5678-9abc/json/6/0/UNREACH
03/26/17 18:25:37.048 RPC client: Info: Calling RPC method "system.multicall" on server 192.168.178.28.
03/26/17 18:25:37.048 Info: Publishing topic homegear/1234-5678-9abc/plain/6/0/UNREACH
03/26/17 18:25:37.049 Info: Publishing topic homegear/1234-5678-9abc/jsonobj/6/0/UNREACH
03/26/17 18:25:37.049 Info: Publishing topic homegear/1234-5678-9abc/json/6/0/STICKY_UNREACH
03/26/17 18:25:37.049 Info: Publishing topic homegear/1234-5678-9abc/plain/6/0/STICKY_UNREACH
03/26/17 18:25:37.050 Info: Publishing topic homegear/1234-5678-9abc/jsonobj/6/0/STICKY_UNREACH
03/26/17 18:25:37.887 Info: Peer 6 is reachable again.
03/26/17 18:25:37.888 Info: Publishing topic homegear/1234-5678-9abc/json/6/0/UNREACH
03/26/17 18:25:37.888 RPC client: Info: Calling RPC method "system.multicall" on server 192.168.178.28.
03/26/17 18:25:37.888 Info: Publishing topic homegear/1234-5678-9abc/plain/6/0/UNREACH
03/26/17 18:25:37.888 Info: Publishing topic homegear/1234-5678-9abc/jsonobj/6/0/UNREACH
Das Problem habe ich mit allen Aktoren im Haus :-/
Zur Kommunikation nutze ich ein LAN-Gateway, welchen ich auch schon einmal neugestartet habe.
Eine Idee, wie ich dem Problem auf den Grund gehen kann?
Grüße
Sven
