Dabei ist mir übrigends aufgefallen, dass während der Installationsphase einige Fehler “durchrauschen”. Ich habe mal rauskopiert, was ich so gesehen habe. Zwischen den Fehlermeldungen lagen teilweise mehrere Seiten Statusmeldungen.
Processing triggers for systemd (215-17+deb8u3) ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
Selecting previously unselected package homegear-homematicbidcos.
(Reading database ... 26275 files and directories currently installed.)
Preparing to unpack homegear-homematicbidcos_current_raspbian_jessie_armhf.deb ...
Unpacking homegear-homematicbidcos (0.6.0-1274) ...
dpkg: dependency problems prevent configuration of homegear-homematicbidcos:
homegear-homematicbidcos depends on homegear (= 0.6.0-1274); however:
Package homegear is not configured yet.
dpkg: error processing package homegear-homematicbidcos (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
2016-03-27 13:25:42 (444 KB/s) - â/tmp/HomegearTemp/HM-Sen-MDIR-WM55_update_V1_1_2_150413.tgzâ saved [51571/51571]
Family initialization failed. See log for more details.
### Please modify the file /etc/homegear/families/homematicbidcos.conf ###
### according to your needs and restart Homegear. ###
Selecting previously unselected package homegear-homematicwired.
(Reading database ... 26392 files and directories currently installed.)
Preparing to unpack homegear-homematicwired_current_raspbian_jessie_armhf.deb ...
Unpacking homegear-homematicwired (0.6.0-1274) ...
Setting up homegear-homematicwired (0.6.0-1274) ...
Downloading current firmware updates...
Generating DH parameters, 1024 bit long safe prime, generator 5
This is going to take a long time
DH parameters appear to be ok.
Failed to start homegear.service: Unit homegear.service failed to load: No such file or directory.
dpkg: error processing package homegear (--configure):
subprocess installed post-installation script returned error exit status 6
Setting up enchant (1.6.0-10.1) ...
Setting up libglib2.0-data (2.42.1-1) ...
Setting up shared-mime-info (1.3-1) ...
Setting up xdg-user-dirs (0.15-2) ...
Processing triggers for libc-bin (2.19-18+deb8u3) ...
Processing triggers for dictionaries-common (1.23.17) ...
