ich kämpfe derzeit mit einem No Answer from Device Fehler bei meinem Jalousie-Aktor.
Meine Umgebung:
openHAB 2.5.4-1 (Release Build)
Homegear (version 0.7.39-2773)
Raspberry Pi 3 Model B Rev 1.2
Betroffenes Gerät:
HM-LC-Bl1PBU-FM
Die drei anderen Geräte funktionieren einwandfrei.
Openhab.log Fehler
OEQ0037312:1
LEVEL
0.0
at org.openhab.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:51) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:82) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:94) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:70) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:334) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:686) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:65) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:665) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:644) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.sendDatapoint(HomematicThingHandler.java:306) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:282) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor103.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_152]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_152]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy262.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor102.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_152]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_152]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
Aus den anderen Themen habe ich entnommen, dass ein Log File mit LogLevel 5 hilfreich ist. Hier ist eines:
homegear.log (407,2 KB)
Würde mich natürlich sehr über Hilfe/Tipps freuen. Danke.
