InstallNightly.sh is looking for https://downloads.homegear.eu/nightlies/homegear-nodes-ui_current_raspbian_buster_armhf.deb
But the homegear-nodes-ui* files are missing for raspbian and ubuntu.
Ok,
0.8.0-3227 has been replaced by 0.8.0-3231.
Now there is an error with homegear-licensing …
Preparing to unpack homegear-licensing_current_raspbian_buster_armhf.deb ...
Unpacking homegear-licensing (0.8.0-3227) ...
dpkg: dependency problems prevent configuration of homegear-licensing:
homegear-licensing depends on libhomegear-base (= 0.8.0-3227); however:
Version of libhomegear-base on system is 0.8.0-3231.
homegear-licensing depends on homegear (= 0.8.0-3227); however:
Version of homegear on system is 0.8.0-3231.
dpkg: error processing package homegear-licensing (--install):
dependency problems - leaving unconfigured
homegear-licensing
Switching back to 3225 did not work, since the new InstallNightly.sh script was looking for “homegear-nodes-ui”
Just installed 3244 on Raspbian Buster (RaspBerryPi 4).
First test works without problem.
Nodeblue starting is ok.
Display of “°C” in AdminUI device variable is fine now
Autocorrection on setting float Values is as upgly as before
Good job boys.
Sorry, some versions in between did not work - there were a lot of changes during the last weeks. Now I think the nightlies are pretty stable again.
