[solved] nanoCUL + Homegear + MAX pairing nicht möglich
ich habe Probleme beim Pairing eines MAX Thermostats mit Homegear.
nach der Erstellung des Topics im englischen Forum habe ich noch homegear-max installiert.
das homegear.log gibt nach dem neuen Versuch folgendes aus:
01/22/19 15:26:18.341 RPC Server (Port 2001): Info: Client number 11 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 15:26:24.555 Module MAX: CUL “My-MAX-CUL”: Warning: Too short packet received: 5513136383837393612
01/22/19 15:26:29.554 HomeMatic BidCoS packet received (traxCUL868, RSSI: -74 dBm): 09700040019E02900000
01/22/19 15:26:33.345 RPC Server (Port 2001): Info: Client number 11 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 15:26:33.350 RPC Server (Port 2001): Info: Client number 11 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 15:26:34.554 Module MAX: Warning: Packet is shorter than value of packet length byte: Z704090900010A4533333332^MZ70401E20000010F533887969
01/22/19 15:26:34.554 MAX packet received (My-MAX-CUL): 184090900010A45333333302000401E20000010F5338879609
01/22/19 15:26:39.554 MAX packet received (My-MAX-CUL, RSSI: 0x0E): 0901E2000010A4451688
01/22/19 15:26:44.554 HomeMatic BidCoS packet received (traxCUL868, RSSI: -130 dBm): 1000909000010A44511633333101704090
01/22/19 15:26:48.355 RPC Server (Port 2001): Info: Client number 11 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 15:26:48.362 RPC Server (Port 2001): Info: Client number 11 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 15:26:49.554 MAX packet received (My-MAX-CUL, RSSI: 0x31): 090909000010A4453333
01/22/19 15:26:58.284 IPC Server: Info: Connection to IPC server’s client number 9 closed.
homematicbidcos.conf sieht so aus:
centralAddress = 0xFD21FB
[CUL]
id = traxCUL868
deviceType = cul
device = /dev/ttyUSB0
responseDelay = 40
max.conf sieht so aus:
[General]
moduleEnabled = true
[CUL]
id = My-MAX-CUL
deviceType = cul
responseDelay = 40
minicom gibt folgendes aus:
V
V 1.67 nanoCUL868
C99
72E2E0DE9CAFF0C
45000006002165A
C8930322F8340733
18166C43401876B
F85610AC2B181141
00597FE81350B00
Beim pairing gibt minicom folgendes aus:
Z1700040019E029000000001001A04F45513136383837393614
A1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE21
776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE22
1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE23
Liegt es an der Fehlermeldung “Warning: Too short packet received”?
Hat jemand eine Lösung parat?
Danke und Gruß
Florian
Habe homegear-homematicbidcos deinstalliert. Pairing innerhalb von drei Sekunden erfolgreich.
Hoffentlich bleibt das so stabil
Florian
Warum hast Du eigentlich homematicbidcos installiert, bzw. konfiguriert?
Die reine Installation sollte nichts bewirken, aber deine homematicbiscos.conf zeigt auf das gleiche Gerät wie deine max.conf (/dev/ttyUSB0). Das kann so nicht funktionieren.
