Openhabian & homegear & hm-mod-rpi-pcb führen zu fehlermeldung
hallo forum,
nach installtion der aktuellen software bekomme ich in den logdateien folgende fehlermeldungen.
[13:46:25] root@openHABianPi:/var/log/homegear# tail -f homegear.log
12/21/17 13:03:17.232 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.37:61818 accepted. Client number: 833
12/21/17 13:03:17.234 RPC Server (Port 2001): Info: RPC server client id for client number 833 is: 747
12/21/17 13:03:17.235 RPC Server (Port 2001): Info: Client number 833 is calling RPC method: listBidcosInterfaces (2) Parameters:
12/21/17 13:03:17.334 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.37:61819 accepted. Client number: 834
12/21/17 13:03:17.334 RPC Server (Port 2001): Info: RPC server client id for client number 834 is: 748
12/21/17 13:03:17.335 RPC Server (Port 2001): Info: Client number 834 is calling RPC method: getServiceMessages (2) Parameters:
12/21/17 13:03:17.658 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.178.37:61826 accepted. Client number: 835
12/21/17 13:03:17.659 RPC Server (Port 2001): Info: RPC server client id for client number 835 is: 749
12/21/17 13:03:17.660 RPC Server (Port 2001): Info: Client number 835 is calling RPC method: getServiceMessages (2) Parameters:
12/21/17 13:37:49.991 Info: Connection to CLI client number 282 closed.
^C
[13:48:44] root@openHABianPi:/var/log/homegear# tail -f homegear.err
12/21/17 12:25:10.573 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
12/21/17 12:25:10.573 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
12/21/17 12:25:12.147 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
12/21/17 12:25:20.286 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
12/21/17 12:25:20.286 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
12/21/17 12:25:21.860 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
12/21/17 12:25:29.998 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No response received to packet: FD0003000003180A
12/21/17 12:25:29.998 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: Unknown packet received in response to init packet. Reconnecting…
12/21/17 12:25:58.537 Warning: Unknown parameter property: label
leider helfen diese mir nicht weiter.
grafik
Bitte benutz doch die Formatierungsfunktionen des Forums. Danke.
Nun ja, die beiden Logs haben auch nichts miteinander zu tun.
  1. die RPC-Geschichte. openHAB Homematic Binding verbindet sich mit Homegar, fragt was ab, und schließt die Verbindung wieder. Ganz normales Verhalten.
  2. BidCos-Fehler: Die Verbindung zwischen den Geräten und dem HM-MOD-RPI-PCB verabschiedet sich, ist halt Funk. Hatte ich auch ein regelmäßig im Log, außer dem Log war aber kein negatives Verhalten erkennbar.
