Node-blue login password
Hallo Zusammen,
ich habe heute auf die neuste Version geupdated (0.8.0-2203)
und kann mich nicht mehr nach node-blue einloggen. Weder das defaulpasswort in /var/lib/homegear/defaultPassword.txt noch das ursprüngliche Passwort funktioniert.
Das Log sieht eigentlich ganz vernünftig aus:
05/20/18 12:31:12.895 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:13978 accepted. Client number: 81
05/20/18 12:31:12.895 RPC Server (Port 2001): Info: RPC server client id for client number 81 is: 14
05/20/18 12:31:12.899 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:13979 accepted. Client number: 82
05/20/18 12:31:12.899 RPC Server (Port 2001): Info: RPC server client id for client number 82 is: 15
05/20/18 12:31:12.901 Web server (Port 2001): Client is requesting: /node-blue/vendor/bootstrap/css/bootstrap.min.css (translated to /var/lib/homegear/www/rpc/node-blue/vendor/bootstrap/css/bootstrap.min.css, method: GET)
05/20/18 12:31:12.901 Web server (Port 2001): Client is requesting: /node-blue/red/images/node-blue.svg (translated to /var/lib/homegear/www/rpc/node-blue/red/images/node-blue.svg, method: GET)
05/20/18 12:31:14.560 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:13980 accepted. Client number: 84
05/20/18 12:31:14.561 RPC Server (Port 2001): Info: RPC server client id for client number 84 is: 16
05/20/18 12:31:14.696 Web server (Port 2001): Client is requesting: /node-blue/signin.php (translated to /var/lib/homegear/www/rpc/node-blue/signin.php, method: POST)
05/20/18 12:31:14.706 Web server (Port 2001): Client is requesting: /node-blue/signin.php (translated to: "/var/lib/homegear/www/rpc/node-blue/signin.php", method: POST)
05/20/18 12:31:14.706 Script Engine Server: Info: Starting script "/var/lib/homegear/node-blue/www/signin.php" with id 6.
05/20/18 12:31:14.717 Script Engine Server: Info: Client number 0 is calling RPC method: auth
05/20/18 12:31:14.719 Script Engine Server: Info: Client number 0 is calling RPC method: checkServiceAccess
05/20/18 12:31:14.721 Script Engine Server: Info: Client number 0 is calling RPC method: scriptHeaders
05/20/18 12:31:14.723 Script Engine Server: Info: Client number 0 is calling RPC method: scriptOutput
05/20/18 12:31:14.726 Info: Script with id 6 finished with exit code 0
05/20/18 12:31:14.746 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:13981 accepted. Client number: 85
05/20/18 12:31:14.747 RPC Server (Port 2001): Info: RPC server client id for client number 85 is: 17
05/20/18 12:31:14.748 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:13982 accepted. Client number: 86
05/20/18 12:31:14.748 RPC Server (Port 2001): Info: RPC server client id for client number 86 is: 18
05/20/18 12:31:14.749 Web server (Port 2001): Client is requesting: /node-blue/vendor/bootstrap/css/bootstrap.min.css (translated to /var/lib/homegear/www/rpc/node-blue/vendor/bootstrap/css/bootstrap.min.css, method: GET)
05/20/18 12:31:14.750 Web server (Port 2001): Client is requesting: /node-blue/red/images/node-blue.svg (translated to /var/lib/homegear/www/rpc/node-blue/red/images/node-blue.svg, method: GET)
Gerade nochmal ein wenig getestet. Es muss sich irgendwas zwischen 2186 und 2189 eingeschlichen haben.
Bis 2186 funktioniert es ohne Probleme.
Hallo @trilu,
da sind ACLs für Dienste dazugekommen. Bei der Aktualisierung fehlen die entsprechenden Berechtigungen. Ich werde morgen mal sehen, ob ich diese in diesem Falle irgendwie hinzufüge. Bis dahin:
homegear -e rc 'print_v($hg->updateGroup(1, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(2, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(3, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(4, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(5, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(6, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(7, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(8, array("eventServerMethods" => array("*" => true),"methods" => array("*" => true),"services" => array("*" => true))));'
homegear -e rc 'print_v($hg->updateGroup(9, array("eventServerMethods" => array("*" => false),"methods" => array("*" => false),"services" => array("*" => false))));'
Vielen Dank!! Hat funktioniert.
:+1:
