Keine pairing möglich -->Error: No init packet received
nachdem meine SD Karte gestorben ist und ich dummer weise keine Backup gemacht habe muss ich meine Homegear komponenten neu anlernen. Dies funktioniert leider nicht. Die Homematic Schalter habe ich bereits über den Hardwaretaster resetet.
folgendes steht im Homegear log.
(String) c978271e
03/08/18 20:40:50.358 RPC Server (Port 2001): Info: Client number 25 is calling RPC method: ping (2) Parameters:
(String) c978271e
03/08/18 20:41:01.808 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No init packet received.
03/08/18 20:41:02.872 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Connection closed (1). Trying to reconnect…
03/08/18 20:41:04.873 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Connected to HM-MOD-RPI-PCB.
03/08/18 20:41:05.010 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Too large packet received: 000C000000436F
03/08/18 20:41:05.010 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: Too large packet received: 4350555F424C72
03/08/18 20:41:05.366 RPC Server (Port 2001): Info: Client number 25 is calling RPC method: ping (2) Parameters:
Rfkey habe ich damals glücklicher weise gesichert.
hier meine homematicbidcos.config:
> ########## General Settings  ##########
> [General]
> ## The BidCoS address of Homegear. It is recommended to change this to a random 3 byte hexadecimal
> ## value starting with 0xFD (e. g. 0xFD43AB). Only change this, when no HomeMatic BidCoS devices
> ## are paired to Homegear as existing pairings will not work anymore!
> centralAddress = 0xFD0001
> ## Specify a 16 byte (32 characters) long AES key here to protect your wireless communication
> ## !!! IMPORTANT: It is highly recommended to change this key before pairing the first device.
> ## !!! IMPORTANT: Never ever lose this key. That would render your devices useless.
> ## To remove the key from your devices, you need to factory reset them using Homegear. The factory
> ## reset on the device is not possible!!!
> rfKey = xxxxxxxxxxxxxxxxxxxxxxxx
> ## With each key change currentRFKeyIndex needs to be
> ## incremented by 1
> currentRfKeyIndex = 1
> ## When you change rfKey, put the old key here. To change the key Homegear needs to know the
> ## old and the new one.
> ## !!! Do not set oldRFKey when you set rfKey for the first time !!!
> ##oldRFKey = 00112233445566778899AABBCCDDEEFF
> ## When set to "true" unsigned broadcast packets are processed by Homegear. This could enable an
> ## attacker to make Homegear do things, you don't want. That means, this option is a security
> ## risk.
> processBroadcastWithAesEnabled = false
id = My-HM-MOD-RPI-PCB
# Uncomment this if you want the HM-MOD-RPI-PCB to be your default communication module.
#default = true
deviceType = hm-mod-rpi-pcb
device = /dev/ttyAMA0
responseDelay = 95
gpio1 = 18
kann es sein das der HM-MOD-RPI-PCB auch defekt ist?
Vielen Dank für eure Hilfe
Hast du die Konfiguration wie beschrieben angepasst?
https://doc.homegear.eu/data/homegear-homematicbidcos/configuration.html#homematic-wireless-module-for-raspberry-pi-hm-mod-rpi-pcb
Danke für den Tip, das hatte ich noch nicht gemacht.
Nun funktioniert alles
