Homegear Konfiguration für Intertechno Geräte
Hallo @sathya,
leider funktioniert the kanal mit typ 0x10 noch nicht. Anbei der Auszug mit dl 5.
Der Hinweis im Log mit den möglichen Typen und Beispielen ist auf jeden Fall hilfreich. Ich habe auch beide Adressen probiert: 0x01574D6A or 0x81574D6A.
Beides geht aktuell nicht.
Anbei die genutzte Homegear version 0.7.30-1900
VG becksen
02/26/19 22:27:27.049 Debug (My-IT-CUL): Packet 6666A65A6699969625 enters raisePacketReceived.
02/26/19 22:27:27.049 Debug (My-IT-CUL): Packet 6666A65A6699969625 is now passed to the EventHandler.
02/26/19 22:27:27.049 Intertechno packet received from 01574D6A (RSSI: -62 dBm): 01
02/26/19 22:27:27.049 Please use one of the following addresses for device creation (possible device types: 0x10 to 0x1F): 0x01574D6A or 0x81574D6A
02/26/19 22:27:27.050 Debug (My-IT-CUL): Packet processing of packet 6666A65A6699969625 took 1 ms.
02/26/19 22:27:27.052 RPC client: Debug: Calling RPC method "system.multicall" on server 192.168.XXX.XXX.
02/26/19 22:27:27.052 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
    [methodName]
      (String) event
    [params]
      (Array length=4)
        (String) RF-1c2190fb
        (String) ITD01574D6A:0
        (String) RSSI_DEVICE
        (Integer) -194
02/26/19 22:27:27.053 Debug: Calling getFileDescriptor...
02/26/19 22:27:27.053 Debug: Connecting to host 192.168.XXX.XXX on port 9126...
02/26/19 22:27:27.054 Debug: Connected to host 192.168.XXX.XXX on port 9126. Client number is: 168
02/26/19 22:27:27.054 RPC client: Debug: Sending packet: 42696E00000000980000001073797374656D2E6D756C746963616C6C000000010000010000000001000001010000000200$
02/26/19 22:27:27.066 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
02/26/19 22:27:27.067 RPC client: Debug: Received packet from server 192.168.XXX.XXX: 42696E0100000015000001000000000100000003000000056576656E74
02/26/19 22:27:27.067 RPC client: Response was:
(Array length=1)
  (String) event
02/26/19 22:27:34.306 Debug (My-IT-CUL): Packet 6666A65A6699959623 enters raisePacketReceived.
02/26/19 22:27:34.306 Debug (My-IT-CUL): Packet 6666A65A6699959623 is now passed to the EventHandler.
02/26/19 22:27:34.306 Intertechno packet received from 01574D6A (RSSI: -63 dBm): 00
02/26/19 22:27:34.306 Please use one of the following addresses for device creation (possible device types: 0x10 to 0x1F): 0x01574D6A or 0x81574D6A
02/26/19 22:27:34.307 Debug (My-IT-CUL): Packet processing of packet 6666A65A6699959623 took 1 ms.
02/26/19 22:27:35.611 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000083163323139306662
02/26/19 22:27:35.611 RPC Server (Port 2001): Info: Client number 116 is calling RPC method: ping (2) Parameters:
(String) 1c2190fb
02/26/19 22:27:35.611 RPC Server (Port 2001): Response:
(Boolean) 1
