Noch ein Update. Gerade hat es einmal funktioniert. Hier der Vollständigkeit halber der Logauszug:
[quote]11/22/15 13:09:14.189 Info: Connected to host 192.168.5.12 on port 9123. Client number is: 7183
11/22/15 13:09:24.302 Module HomeMatic BidCoS: Info: INSTALL_TEST on channel 1 of HomeMatic BidCoS peer 24 with serial number XXXX was set to 0x39.
11/22/15 13:09:24.303 Module HomeMatic BidCoS: Info: PRESS_SHORT on channel 1 of HomeMatic BidCoS peer 24 with serial number XXXX was set to 0x39.
11/22/15 13:09:24.301 HomeMatic BidCoS packet received (hmlan1, RSSI: 0x31): 0B7FA24033B84CFD06290139
11/22/15 13:09:24.304 Info: Event “Switch Switching” raised for peer with id 24, channel 1 and variable “PRESS_SHORT”. Trigger: "value"
11/22/15 13:09:24.305 RPC Server (Port 2001): Info: RPC Method called: putParamset Parameters:
(Integer) 24
(Integer) 1
(String) MASTER
(Struct length=1)
[TEXTLINE_1]
(String) 021280118313820A0A13810A0A12333411830A0A03
11/22/15 13:09:24.306 Module HomeMatic BidCoS: Info: Parameter TEXTLINE_1 of peer 24 and channel 1 was set to 0x303231323830313138333133383230413041313338313041304131323333333431313833304130413033.
11/22/15 13:09:24.308 RPC client: Info: Calling RPC method “system.multicall” on server 192.168.5.12.
11/22/15 13:09:24.319 Info: Connecting to host 192.168.5.12 on port 9123…
11/22/15 13:09:24.325 Info: Connected to host 192.168.5.12 on port 9123. Client number is: 7184
11/22/15 13:09:24.335 RPC client: Info: Calling RPC method “system.multicall” on server 192.168.5.12.
11/22/15 13:09:24.336 Info: Connecting to host 192.168.5.12 on port 9123…
11/22/15 13:09:24.341 Info: Connected to host 192.168.5.12 on port 9123. Client number is: 7185
11/22/15 13:09:24.360 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “hmlan1”: Info: Sending (hmlan1): 1A9AA011FD062933B84C8002021280118313820A0A13810A0A1233
11/22/15 13:09:24.819 HomeMatic BidCoS packet received (hmlan1, RSSI: 0x30): 0A9A800233B84CFD062900
11/22/15 13:09:24.878 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “hmlan1”: Info: Sending (hmlan1): 119BA011FD062933B84C80023411830A0A03
11/22/15 13:09:25.211 HomeMatic BidCoS packet received (hmlan1, RSSI: 0x31): 0A9B800233B84CFD062900
11/22/15 13:09:25.270 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “hmlan1”: Info: Sending (hmlan1): 109CA001FD062933B84C01050000000001
[/quote]
Grüße,
Seppy
