Communication issue HG-HM-LC-Sw4-WM - No answer from device
Hi,
I am looking for hints on how I could fix the below described issue that I face with a Homematic HG-HM-LC-Sw4-WM that a lately installed. I have two other Homematic devices in my environment that work properly. The new device is not working properly and when I check the logs I see that there is some kind of communication issue (na answer from device). What I did so far:
Removed the thing and added the thing again.
update/upgrade openHAB
reinstalled homegear
updated homegear
Nothing helped. So I set the debug level for Homematic to DEBUG. As I am not able to interpret the log myself it would be great if someone could give me a hint.
My environment:
Openhab = openHAB 2.4.0-1 (Release Build)
Homegear = 0.7.39-2773
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Wireless Module for Homematic = HM-MOD-RPI-PCB
06:30:14.898 [INFO ] [smarthome.event.ItemStateChangedEvent] - Hm1Ch1_2_State changed from OFF to ON
06:30:14.897 [DEBUG] [mematic.handler.HomematicThingHandler] -     Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:2#STATE'
06:30:14.916 [DEBUG] [communicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:2#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
06:30:17.489 [DEBUG] [rnal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
06:30:20.072 [ERROR] [mematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:2
STATE
true
java.io.IOException: -100 No answer from device. (sending setValue()
PEQ1419156:2
STATE
true
at org.eclipse.smarthome.binding.homematic.internal.communicator.parser.RpcResponseParser.parse(RpcResponseParser.java:51) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:82) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:94) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.BinRpcClient.sendMessage(BinRpcClient.java:70) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.client.RpcClient.setDatapointValue(RpcClient.java:335) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway$1.execute(AbstractHomematicGateway.java:686) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.misc.DelayedExecuter.start(DelayedExecuter.java:65) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:665) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.internal.communicator.AbstractHomematicGateway.sendDatapoint(AbstractHomematicGateway.java:644) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.sendDatapoint(HomematicThingHandler.java:307) ~[198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.binding.homematic.handler.HomematicThingHandler.handleCommand(HomematicThingHandler.java:283) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor102.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy127.handleCommand(Unknown Source) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
at java.lang.Thread.run(Thread.java:748) [?:?]
Hey @bummzulu,
this is an openhab Log… could you check the homegear log while this happens?
The log is in /var/log/homegear.log. You can change the loglevel of homegear at runtime:
sudo homegear -r
dl 4
Debug Leve (dl) 3 is the default, 4 should be enough… if nothing is logged, check dl 5.
Hi @pmayer
thanks for the detailed instruction. Hope the log level was sufficient.
I increased the log level and replicated the issue at 08:03:59 according the openhab.log:
2019-07-13 08:03:53.968 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:4#STATE'
2019-07-13 08:03:53.983 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:4#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:03:56.550 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:03:59.120 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:4
STATE
true
PEQ1419156:4
STATE
true
2019-07-13 08:04:00.244 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-13 08:04:04.105 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'OFF' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:4#STATE'
2019-07-13 08:04:04.115 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:4#STATE' with value 'false' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:04:06.694 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:04:09.267 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:4
STATE
false
PEQ1419156:4
STATE
false
2019-07-13 08:04:09.300 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:3#STATE'
2019-07-13 08:04:09.307 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:3#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:04:11.872 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:04:14.443 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:3
STATE
true
PEQ1419156:3
STATE
true
2019-07-13 08:04:14.474 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'OFF' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:3#STATE'
2019-07-13 08:04:14.481 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:3#STATE' with value 'false' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:04:17.045 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:04:19.630 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-13 08:04:19.625 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:3
STATE
false
PEQ1419156:3
STATE
false
2019-07-13 08:04:23.253 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:04:23.289 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#STICKY_UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:04:25.556 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:04:34.641 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-13 08:04:38.258 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:3#STATE'
2019-07-13 08:04:38.269 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:3#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:04:38.388 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
	at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: org.eclipse.jetty.io.EofException
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:798) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:538) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:790) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:846) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:240) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:216) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:541) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
	at java.io.OutputStream.write(OutputStream.java:75) ~[?:?]
	at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
	at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[?:?]
	at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
	at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
	... 53 more
Caused by: java.io.IOException: Broken pipe
	at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
	at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
	at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
	at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
	at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:266) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
	... 53 more
2019-07-13 08:04:38.699 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Integer) value '-55' for 'PEQ1419156:0#RSSI_DEVICE' from gateway with id 'dcd1d685'
2019-07-13 08:04:40.841 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:04:43.415 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:3
STATE
true
PEQ1419156:3
STATE
true
2019-07-13 08:04:44.613 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'OFF' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:3#STATE'
2019-07-13 08:04:44.679 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:3#STATE' with value 'false' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-13 08:04:47.254 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-13 08:04:49.829 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:3
STATE
false
PEQ1419156:3
STATE
false
2019-07-13 08:04:49.838 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-13 08:04:56.526 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:04:56.539 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#STICKY_UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:04:58.495 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
2019-07-13 08:05:04.847 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-13 08:05:15.469 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
	... 53 more
	... 53 more
Here is the corresponding homegear.log:
07/13/19 08:03:00.195 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
(String) dcd1d685
07/13/19 08:03:00.199 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:03:15.204 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:03:15.210 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:03:22.644 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -58 dBm): 1496845E55405000000093ACAC0000040000090FFF
07/13/19 08:03:22.645 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 2 with serial number OEQ0022366 was set to 0x0000.
07/13/19 08:03:22.645 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 2 with serial number OEQ0022366 was set to 0x13ACAC.
07/13/19 08:03:22.645 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 2 with serial number OEQ0022366 was set to 0xFF.
07/13/19 08:03:22.645 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 2 with serial number OEQ0022366 was set to 0x000004.
07/13/19 08:03:22.645 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 2 with serial number OEQ0022366 was set to 0x090F.
07/13/19 08:03:30.215 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:03:30.220 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:03:45.225 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:03:45.233 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:03:53.991 RPC Server (Port 2001): Info: Client number 10495 is calling RPC method: setValue (2) Parameters:
(String) PEQ1419156:4
(String) STATE
(Boolean) 1
07/13/19 08:03:53.992 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E82A011FD491F6863CD0204C80000
07/13/19 08:03:55.180 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E82A011FD491F6863CD0204C80000
07/13/19 08:03:56.556 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35052 accepted. Client number: 10512
07/13/19 08:03:56.557 RPC Server (Port 2001): Info: RPC server client id for client number 10512 is: 248
07/13/19 08:03:56.558 RPC Server (Port 2001): Info: Client number 10512 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 1
07/13/19 08:03:59.602 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:03:59.602 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:03:59.702 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E83A011FD491F6863CD0204C80000
07/13/19 08:04:00.241 RPC Server (Port 2001): Info: Client number 10512 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:04:00.244 RPC Server (Port 2001): Info: Client number 10512 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:04:00.574 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E83A011FD491F6863CD0204C80000
07/13/19 08:04:02.708 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:02.708 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:04:02.808 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E83A011FD491F6863CD0204C80000
07/13/19 08:04:03.724 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E83A011FD491F6863CD0204C80000
07/13/19 08:04:04.135 RPC Server (Port 2001): Info: Client number 10512 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/13/19 08:04:06.705 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35066 accepted. Client number: 10514
07/13/19 08:04:06.706 RPC Server (Port 2001): Info: RPC server client id for client number 10514 is: 249
07/13/19 08:04:06.708 RPC Server (Port 2001): Info: Client number 10514 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/13/19 08:04:09.313 RPC Server (Port 2001): Info: Client number 10514 is calling RPC method: setValue (2) Parameters:
(String) PEQ1419156:3
(String) STATE
(Boolean) 1
07/13/19 08:04:11.880 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35068 accepted. Client number: 10515
(Boolean) 1
07/13/19 08:04:11.881 RPC Server (Port 2001): Info: RPC server client id for client number 10515 is: 250
07/13/19 08:04:11.883 RPC Server (Port 2001): Info: Client number 10515 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 1
07/13/19 08:04:14.487 RPC Server (Port 2001): Info: Client number 10515 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/13/19 08:04:17.051 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35106 accepted. Client number: 10516
07/13/19 08:04:17.051 RPC Server (Port 2001): Info: RPC server client id for client number 10516 is: 251
07/13/19 08:04:17.053 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/13/19 08:04:19.625 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:04:19.629 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:04:20.140 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:20.140 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:04:20.240 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E85A011FD491F6863CD0204000000
07/13/19 08:04:21.077 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E85A011FD491F6863CD0204000000
07/13/19 08:04:23.245 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:23.247 Info: Peer 3 is unreachable.
07/13/19 08:04:25.552 Info: Peer 3 is reachable again.
07/13/19 08:04:34.635 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:04:34.640 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:04:38.282 RPC Server (Port 2001): Info: Client number 10516 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 1
07/13/19 08:04:38.284 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E85A011FD491F6863CD0204000000
07/13/19 08:04:38.696 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -55 dBm): 128580026863CDFD491F0104000040559BDF22
07/13/19 08:04:38.790 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E8AA011FD491F6863CD0203C80000
07/13/19 08:04:39.977 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E8AA011FD491F6863CD0203C80000
07/13/19 08:04:40.850 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35154 accepted. Client number: 10522
07/13/19 08:04:40.851 RPC Server (Port 2001): Info: RPC server client id for client number 10522 is: 252
07/13/19 08:04:40.852 RPC Server (Port 2001): Info: Client number 10522 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 1
07/13/19 08:04:43.893 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:43.893 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:04:43.993 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E8BA011FD491F6863CD0203C80000
07/13/19 08:04:44.696 RPC Server (Port 2001): Info: Client number 10522 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/13/19 08:04:44.959 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E8BA011FD491F6863CD0203C80000
07/13/19 08:04:47.262 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:35166 accepted. Client number: 10523
07/13/19 08:04:47.262 RPC Server (Port 2001): Info: RPC server client id for client number 10523 is: 253
07/13/19 08:04:47.263 RPC Server (Port 2001): Info: Client number 10523 is calling RPC method: setValue (2) Parameters:
(String) STATE
(String) STATE
(Boolean) 0
07/13/19 08:04:49.829 RPC Server (Port 2001): Info: Client number 10523 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:04:49.836 RPC Server (Port 2001): Info: Client number 10523 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/13/19 08:04:50.307 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:50.307 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:04:50.407 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E8DA011FD491F6863CD0203000000
07/13/19 08:04:51.310 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E8DA011FD491F6863CD0203000000
07/13/19 08:04:53.412 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:53.412 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/13/19 08:04:53.513 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0E8DA011FD491F6863CD0203000000
07/13/19 08:04:54.412 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0E8DA011FD491F6863CD0203000000
07/13/19 08:04:56.518 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/13/19 08:04:56.518 Info: Peer 3 is unreachable.
07/13/19 08:04:58.491 Info: Peer 3 is reachable again.
07/13/19 08:05:04.842 RPC Server (Port 2001): Info: Client number 10523 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/13/19 08:05:04.853 RPC Server (Port 2001): Info: Client number 10523 is calling RPC method: listBidcosInterfaces (2) Parameters:
I tried to extract only the necessary parts from the logs to not flood you with data. Let me know if I can help you better in helping me :slight_smile:
Thanks again!
It seems that homegear can’t setValue on a device and afterwards setting the device to unreachable.
The problem here seems to be that PEQ1419156:4 (String) is trying to be set on STATE which is boolean… this does not fit.
Where is the coresponging setValue on openHab side coming from?
//edit:
Ok, forget about that. Obivously openHab tries to set STATE on the peer with PEQ1419156:4.
Could you give us the output of:
sudo homegear -r
fs 0
ls
Here is the information you asked for:
In the meanwhile I did unpair, reset and remove the device from homematic. I removed all related things/items from openhab. Took me some time to pair it again. Now I have only configured one switch for testing purposes in openhab.
Unfortunately still the same issue. Though it is not appearing constantly. Sometimes it works fine and I can quickly toggle the switches. Then again the issue:
Openhab:
2019-07-14 10:41:04.456 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'ON' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:1#STATE'
2019-07-14 10:41:04.463 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:1#STATE' with value 'true' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-14 10:41:07.039 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-14 10:41:09.608 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:1
STATE
true
PEQ1419156:1
STATE
true
	at sun.reflect.GeneratedMethodAccessor179.invoke(Unknown Source) ~[?:?]
	at com.sun.proxy.$Proxy133.handleCommand(Unknown Source) [198:org.eclipse.smarthome.binding.homematic:0.10.0.oh240]
	at sun.reflect.GeneratedMethodAccessor178.invoke(Unknown Source) ~[?:?]
2019-07-14 10:41:09.644 [DEBUG] [ematic.handler.HomematicThingHandler] - Received command 'OFF' for channel 'homematic:HG-HM-LC-Sw4-WM:dcd1d685:PEQ1419156:1#STATE'
2019-07-14 10:41:09.650 [DEBUG] [ommunicator.AbstractHomematicGateway] - Sending datapoint 'PEQ1419156:1#STATE' with value 'false' to gateway with id 'dcd1d685' using rxMode 'DEFAULT'
2019-07-14 10:41:12.214 [DEBUG] [nal.communicator.client.BinRpcClient] - BinRpcMessage socket failure, sending message again 1/1
2019-07-14 10:41:14.785 [ERROR] [ematic.handler.HomematicThingHandler] - -100 No answer from device. (sending setValue()
PEQ1419156:1
STATE
false
PEQ1419156:1
STATE
false
2019-07-14 10:41:17.293 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (String) value 'dcd1d685' for 'CENTRAL:0#PONG' from gateway with id 'dcd1d685'
2019-07-14 10:41:24.622 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
2019-07-14 10:41:24.652 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'true' for 'PEQ1419156:0#STICKY_UNREACH' from gateway with id 'dcd1d685'
2019-07-14 10:41:27.711 [DEBUG] [ommunicator.AbstractHomematicGateway] - Received new (Boolean) value 'false' for 'PEQ1419156:0#UNREACH' from gateway with id 'dcd1d685'
Homegear:
07/14/19 10:41:02.271 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000086463643164363835
07/14/19 10:41:02.272 RPC Server (Port 2001): Info: Client number 7133 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/14/19 10:41:02.272 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:02.273 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
[methodName] (String) event
[params] (Array length=4)
  (String) RF-dcd1d685
  (String) CENTRAL
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:02.273 Debug: Calling getFileDescriptor...
07/14/19 10:41:02.273 Debug: Connecting to host 10.0.0.45 on port 9126...
07/14/19 10:41:02.273 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7211
07/14/19 10:41:02.274 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6463643164363835000000030000000743454E5452414C0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:02.275 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
07/14/19 10:41:02.275 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
[params] (Array length=5)
  (String) HomegearLib.10.0.0.135:9876
  (Integer64) 0
  (Integer) -1
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:02.276 RPC client: Debug: Sending packet: 42696E00000000A80000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000005000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736000000D1000000000000000000000001FFFFFFFF0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:02.276 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:02.277 RPC Server (Port 2001): Response binary:
42696E01000000050000000201
07/14/19 10:41:02.278 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:02.279 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:02.279 RPC client: Response was:
(String)
07/14/19 10:41:02.280 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:02.280 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:02.281 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:02.281 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
07/14/19 10:41:02.281 RPC Server (Port 2001): Info: Client number 7133 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/14/19 10:41:02.282 RPC Server (Port 2001): Response:
(Array length=1)
  (Struct length=4)
[ADDRESS] (String) VBC0208840
[CONNECTED] (Boolean) 1
[DEFAULT] (Boolean) 1
[DESCRIPTION] (String) Homegear default BidCoS interface
07/14/19 10:41:02.282 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433032303838343000000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
07/14/19 10:41:04.480 RPC Server (Port 2001): Debug: Packet received: 42696E00000000360000000873657456616C756500000003000000030000000C504551313431393135363A31000000030000000553544154450000000201
07/14/19 10:41:04.481 RPC Server (Port 2001): Info: Client number 7133 is calling RPC method: setValue (2) Parameters:
(String) PEQ1419156:1
(String) STATE
(Boolean) 1
07/14/19 10:41:04.481 Module HomeMatic BidCoS: Debug: STATE of peer 3 with serial number PEQ1419156:1 was set to C8.
07/14/19 10:41:04.482 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0EB4A011FD491F6863CD0201C80000
07/14/19 10:41:04.482 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001401C902000000B4A011FC7D491F6863CD0201C800004BBD
07/14/19 10:41:05.409 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000401C9040402
07/14/19 10:41:05.409 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 94
07/14/19 10:41:05.409 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000401C904040294
07/14/19 10:41:05.409 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0EB4A011FD491F6863CD0201C80000
07/14/19 10:41:06.809 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:06.809 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:06.809 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:06.809 RPC Server (Port 2001): Response binary:
07/14/19 10:41:07.036 RPC Server (Port 2001): Response:
(Struct length=2)
  [faultCode] (Integer) -100
  [faultString] (String) No answer from device.
07/14/19 10:41:07.036 RPC Server (Port 2001): Response binary:
42696EFF0000004A0000010100000002000000096661756C74436F646500000001FFFFFF9C0000000B6661756C74537472696E6700000003000000164E6F20616E737765722066726F6D206465766963652E
07/14/19 10:41:07.046 RPC Server (Port 2001): Debug: Connection to client number 7133 closed (3).
07/14/19 10:41:07.047 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:36432 accepted. Client number: 7212
07/14/19 10:41:07.048 RPC Server (Port 2001): Info: RPC server client id for client number 7212 is: 231
07/14/19 10:41:07.049 RPC Server (Port 2001): Listening for incoming packets from client number 7212.
07/14/19 10:41:07.049 RPC Server (Port 2001): Debug: Packet received: 42696E00000000360000000873657456616C756500000003000000030000000C504551313431393135363A31000000030000000553544154450000000201
07/14/19 10:41:07.049 RPC Server (Port 2001): Info: Client number 7212 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 1
07/14/19 10:41:07.049 Module HomeMatic BidCoS: Debug: STATE of peer 3 with serial number PEQ1419156:1 was set to C8.
07/14/19 10:41:09.604 RPC Server (Port 2001): Response:
(Struct length=2)
07/14/19 10:41:09.604 RPC Server (Port 2001): Response binary:
07/14/19 10:41:09.654 RPC Server (Port 2001): Debug: Packet received: 42696E00000000360000000873657456616C756500000003000000030000000C504551313431393135363A31000000030000000553544154450000000200
07/14/19 10:41:09.655 RPC Server (Port 2001): Info: Client number 7212 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/14/19 10:41:09.655 Module HomeMatic BidCoS: Debug: STATE of peer 3 with serial number PEQ1419156:1 was set to 00.
07/14/19 10:41:12.209 RPC Server (Port 2001): Response:
(Struct length=2)
07/14/19 10:41:12.210 RPC Server (Port 2001): Response binary:
07/14/19 10:41:12.218 RPC Server (Port 2001): Debug: Connection to client number 7212 closed (3).
07/14/19 10:41:12.219 RPC Server (Port 2001): Info: Connection from ::ffff:10.0.0.45:36444 accepted. Client number: 7213
07/14/19 10:41:12.220 RPC Server (Port 2001): Info: RPC server client id for client number 7213 is: 232
07/14/19 10:41:12.221 RPC Server (Port 2001): Listening for incoming packets from client number 7213.
07/14/19 10:41:12.221 RPC Server (Port 2001): Debug: Packet received: 42696E00000000360000000873657456616C756500000003000000030000000C504551313431393135363A31000000030000000553544154450000000200
07/14/19 10:41:12.222 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: setValue (2) Parameters:
(String) STATE
(Boolean) 0
07/14/19 10:41:12.222 Module HomeMatic BidCoS: Debug: STATE of peer 3 with serial number PEQ1419156:1 was set to 00.
07/14/19 10:41:14.085 UPnP Server: Debug: Sending notify packets.
07/14/19 10:41:14.782 RPC Server (Port 2001): Response:
(Struct length=2)
07/14/19 10:41:14.782 RPC Server (Port 2001): Response binary:
07/14/19 10:41:15.300 Module HomeMatic BidCoS: Debug: Deleting queue 88 for BidCoS peer with address 0x6863CD
07/14/19 10:41:15.300 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/14/19 10:41:15.300 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/14/19 10:41:15.400 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:15.401 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001401CA02000000B7A011FC7D491F6863CD0201000000FB95
07/14/19 10:41:16.262 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000401CA040402
07/14/19 10:41:16.262 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: A8
07/14/19 10:41:16.262 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000401CA040402A8
07/14/19 10:41:16.262 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:16.832 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:16.832 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:16.832 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:16.832 RPC Server (Port 2001): Response binary:
07/14/19 10:41:17.291 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000086463643164363835
07/14/19 10:41:17.291 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/14/19 10:41:17.291 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:17.291 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
  (String) CENTRAL
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:17.291 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:17.291 Debug: Calling getFileDescriptor...
07/14/19 10:41:17.291 Debug: Connecting to host 10.0.0.45 on port 9126...
07/14/19 10:41:17.291 RPC Server (Port 2001): Response binary:
07/14/19 10:41:17.292 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7214
07/14/19 10:41:17.292 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6463643164363835000000030000000743454E5452414C0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:17.292 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
07/14/19 10:41:17.292 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
  (Integer64) 0
  (Integer) -1
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:17.293 RPC client: Debug: Sending packet: 42696E00000000A80000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000005000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736000000D1000000000000000000000001FFFFFFFF0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:17.295 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
07/14/19 10:41:17.295 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/14/19 10:41:17.295 RPC Server (Port 2001): Response:
(Array length=1)
  (Struct length=4)
07/14/19 10:41:17.295 RPC Server (Port 2001): Response binary:
07/14/19 10:41:17.296 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:17.297 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:17.297 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:17.336 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:17.336 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:17.336 RPC client: Response was:
(String)
07/14/19 10:41:18.405 Module HomeMatic BidCoS: Debug: Deleting queue 89 for BidCoS peer with address 0x6863CD
07/14/19 10:41:18.405 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/14/19 10:41:18.405 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/14/19 10:41:18.505 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:18.506 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001401CB02000000B7A011FC7D491F6863CD02010000006FEE
07/14/19 10:41:19.380 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000401CB040482
07/14/19 10:41:19.380 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: BF
07/14/19 10:41:19.390 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000401CB040482BF
07/14/19 10:41:19.391 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:21.510 Module HomeMatic BidCoS: Debug: Deleting queue 90 for BidCoS peer with address 0x6863CD
07/14/19 10:41:21.510 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/14/19 10:41:21.510 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 3). Retrying...
07/14/19 10:41:21.610 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:21.611 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001401CC02000000B7A011FC7D491F6863CD02010000008285
07/14/19 10:41:22.513 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000401CC040402
07/14/19 10:41:22.514 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: D0
07/14/19 10:41:22.514 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000401CC040402D0
07/14/19 10:41:22.514 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 0EB7A011FD491F6863CD0201000000
07/14/19 10:41:24.616 Module HomeMatic BidCoS: Debug: Deleting queue 91 for BidCoS peer with address 0x6863CD
07/14/19 10:41:24.616 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
07/14/19 10:41:24.616 Info: Peer 3 is unreachable.
07/14/19 10:41:24.617 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:24.618 RPC client: Parameters:
(Array length=2)
  (Struct length=2)
  (String) PEQ1419156:0
  (String) UNREACH
  (Boolean) 1
  (Struct length=2)
  (String) STICKY_UNREACH
  (Boolean) 1
07/14/19 10:41:24.618 Debug: Calling getFileDescriptor...
07/14/19 10:41:24.618 Debug: Connecting to host 10.0.0.45 on port 9126...
07/14/19 10:41:24.619 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7215
07/14/19 10:41:24.619 RPC client: Debug: Sending packet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
07/14/19 10:41:24.620 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
07/14/19 10:41:24.620 RPC client: Parameters:
(Array length=2)
  (Struct length=2)
  (Integer64) 3
  (Integer) 0
  (String) UNREACH
  (Boolean) 1
  (Struct length=2)
  (Integer64) 3
  (Integer) 0
  (Boolean) 1
07/14/19 10:41:24.620 RPC client: Debug: Sending packet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
07/14/19 10:41:24.631 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:24.632 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:24.632 RPC client: Response was:
(String)
07/14/19 10:41:24.660 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:24.661 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:24.661 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:26.825 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:26.825 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:26.825 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:26.825 RPC Server (Port 2001): Response binary:
07/14/19 10:41:27.705 Info: Peer 3 is reachable again.
07/14/19 10:41:27.707 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:27.707 RPC client: Parameters:
07/14/19 10:41:27.707 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
(Array length=1)
  (Struct length=2)
  (String) UNREACH
  (Boolean) 0
07/14/19 10:41:27.707 Debug: Calling getFileDescriptor...
07/14/19 10:41:27.707 Debug: Connecting to host 10.0.0.45 on port 9126...
(Array length=1)
  (Struct length=2)
  (Integer64) 3
  (Integer) 0
  (String) UNREACH
  (Boolean) 0
07/14/19 10:41:27.708 RPC client: Debug: Sending packet: 42696E00000000A00000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000005000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736000000D1000000000000000300000001000000000000000300000007554E52454143480000000200
07/14/19 10:41:27.708 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7216
07/14/19 10:41:27.708 RPC client: Debug: Sending packet: 42696E00000000900000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6463643164363835000000030000000C504551313431393135363A300000000300000007554E52454143480000000200
07/14/19 10:41:27.711 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:27.711 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:27.712 RPC client: Response was:
(String)
07/14/19 10:41:27.722 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:27.722 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:27.723 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:31.530 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00100164050000
07/14/19 10:41:31.530 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 57C780022BC90E48
07/14/19 10:41:31.531 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 241F002B13
07/14/19 10:41:31.531 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010016405000057C780022BC90E48241F002B13
07/14/19 10:41:31.531 Debug (My-HM-MOD-RPI-PCB): Packet 0AC780022BC90E48241F00 enters raisePacketReceived.
07/14/19 10:41:31.532 Debug (My-HM-MOD-RPI-PCB): Packet 0AC780022BC90E48241F00 is now passed to the EventHandler.
07/14/19 10:41:31.531 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -87 dBm): 0AC780022BC90E48241F00
07/14/19 10:41:31.532 Debug (My-HM-MOD-RPI-PCB): Packet processing of packet 0AC780022BC90E48241F00 took 1 ms.
07/14/19 10:41:32.300 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000086463643164363835
07/14/19 10:41:32.300 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/14/19 10:41:32.301 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:32.301 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
  (String) CENTRAL
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:32.301 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
07/14/19 10:41:32.302 Debug: Calling getFileDescriptor...
07/14/19 10:41:32.302 Debug: Connecting to host 10.0.0.45 on port 9126...
(Array length=1)
  (Struct length=2)
  (Integer64) 0
  (Integer) -1
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:32.302 RPC client: Debug: Sending packet: 42696E00000000A80000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000005000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736000000D1000000000000000000000001FFFFFFFF0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:32.302 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7217
07/14/19 10:41:32.302 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6463643164363835000000030000000743454E5452414C0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:32.303 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:32.303 RPC Server (Port 2001): Response binary:
07/14/19 10:41:32.308 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:32.308 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:32.308 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
07/14/19 10:41:32.308 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/14/19 10:41:32.309 RPC client: Response was:
(String)
07/14/19 10:41:32.309 RPC Server (Port 2001): Response:
(Array length=1)
  (Struct length=4)
07/14/19 10:41:32.309 RPC Server (Port 2001): Response binary:
07/14/19 10:41:32.310 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:32.310 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:32.310 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:34.061 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00100165050000
07/14/19 10:41:34.062 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 57C780022BC90E3F
07/14/19 10:41:34.062 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: D4BD00C6C8
07/14/19 10:41:34.062 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0010016505000057C780022BC90E3FD4BD00C6C8
07/14/19 10:41:34.063 Debug (My-HM-MOD-RPI-PCB): Packet 0AC780022BC90E3FD4BD00 enters raisePacketReceived.
07/14/19 10:41:34.063 Debug (My-HM-MOD-RPI-PCB): Packet 0AC780022BC90E3FD4BD00 is now passed to the EventHandler.
07/14/19 10:41:34.063 HomeMatic BidCoS packet received (My-HM-MOD-RPI-PCB, RSSI: -87 dBm): 0AC780022BC90E3FD4BD00
07/14/19 10:41:34.063 Debug (My-HM-MOD-RPI-PCB): Packet processing of packet 0AC780022BC90E3FD4BD00 took 0 ms.
07/14/19 10:41:36.845 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:36.845 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:36.846 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:36.846 RPC Server (Port 2001): Response binary:
07/14/19 10:41:46.856 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:46.856 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:46.856 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:46.856 RPC Server (Port 2001): Response binary:
07/14/19 10:41:47.314 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000086463643164363835
07/14/19 10:41:47.314 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: ping (2) Parameters:
(String) dcd1d685
07/14/19 10:41:47.315 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.45.
07/14/19 10:41:47.315 RPC client: Parameters:
07/14/19 10:41:47.315 RPC Server (Port 2001): Response:
(Array length=1)
  (Struct length=2)
  (String) CENTRAL
  (String) PONG
  (String) dcd1d685
(Boolean) 1
07/14/19 10:41:47.315 RPC client: Debug: Calling RPC method "system.multicall" on server 10.0.0.135.
07/14/19 10:41:47.315 RPC Server (Port 2001): Response binary:
07/14/19 10:41:47.315 Debug: Calling getFileDescriptor...
07/14/19 10:41:47.316 Debug: Connecting to host 10.0.0.45 on port 9126...
07/14/19 10:41:47.316 RPC client: Parameters:
(Array length=1)
  (Struct length=2)
  (Integer64) 0
  (Integer) -1
  (String) PONG
  (String) dcd1d685
07/14/19 10:41:47.316 Debug: Connected to host 10.0.0.45 on port 9126. Client number is: 7218
07/14/19 10:41:47.316 RPC client: Debug: Sending packet: 42696E00000000A80000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000005000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736000000D1000000000000000000000001FFFFFFFF0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:47.316 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D6463643164363835000000030000000743454E5452414C0000000300000004504F4E4700000003000000086463643164363835
07/14/19 10:41:47.319 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
07/14/19 10:41:47.319 RPC Server (Port 2001): Info: Client number 7213 is calling RPC method: listBidcosInterfaces (2) Parameters:
07/14/19 10:41:47.320 RPC Server (Port 2001): Response:
(Array length=1)
  (Struct length=4)
07/14/19 10:41:47.320 RPC Server (Port 2001): Response binary:
07/14/19 10:41:47.320 RPC client: Debug: Packet received: 42696E01000000080000000300000000
07/14/19 10:41:47.320 RPC client: Debug: Received packet from server 10.0.0.135: 42696E01000000080000000300000000
07/14/19 10:41:47.321 RPC client: Response was:
(String)
07/14/19 10:41:47.324 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:47.324 RPC client: Debug: Received packet from server 10.0.0.45: 42696E0100000015000001000000000100000003000000056576656E74
07/14/19 10:41:47.324 RPC client: Response was:
(Array length=1)
  (String) event
07/14/19 10:41:56.869 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000017636C69656E74536572766572496E697469616C697A656400000001000000030000001B486F6D65676561724C69622E31302E302E302E3133353A39383736
07/14/19 10:41:56.869 RPC Server (Port 2001): Info: Client number 6789 is calling RPC method: clientServerInitialized (2) Parameters:
07/14/19 10:41:56.870 RPC Server (Port 2001): Response:
(Boolean) 1
07/14/19 10:41:56.870 RPC Server (Port 2001): Response binary:
Turning on is the value C8 and turning off 00
I try to figure out why homegear sets the device as unreachable
@sathya, do you have any idea?
Nevertheless, openHab simply crashing when this happens is a non welcome situation.
